CAB-13191
CAB-13191
    SPARKFUNELECTRONICS
    11.8"(300.00mm) 接线夹,绝缘 至 尖头插头 测试引线 4 引线,黑色和红色
CAB-13191 数据手册
    Alligator Clip with Pigtail (4 Pack) CAB-13191 RoHS     Description: This is a 4 pack of wires that are pre-terminated with an alligator clip on one end and a hookup pigtail on the other. Alligator clips are a staple part for any workbench and with these cables you will be able to easily incorporate those clips into a breadboard, development platform, or anything else that you would normally be able to attach a hookup wire to. Each Alligator Clip with Pigtail cable has a wire length of 30cm (that’s a little less than 1ft) and a male pin that easily inserts into a standard 0.1" connector. Each pack consists of two red cables and two black cables.                                                 https://www.sparkfun.com/products/13191 4/11/2017
CAB-13191 价格&库存
很抱歉,暂时无法提供与“CAB-13191”相匹配的价格&库存,您可以联系我们找货
