Big Dome Pushbutton - Red
COM -0 9181
Description: It’s the end of the world, and you need a button to press. This is it. A
100mm diameter (outside diameter) dome illuminated push button comes with an
LED, securing nut and a pre-installed long life horizontal microswitch. Button can also
be adjusted to a low profile button by removing the middle ring.
Features:
LED indicator light runs at 12VDC
Bulb holder is easy to install or remove
3 Terminals Button Actuator microswitch included
Microswitch reliability tested to 10,000,000 cycles
Microswitch can be replaced
Polycarbonate lens cap for optical clarity
Dimensions:
• 100 mm Diameter x 72 mm Height
• Net weight: 100grams
• Mounting hole diameter: 24 mm
https://www.sparkfun.com/products/9181
3/14/2017
很抱歉,暂时无法提供与“COM-09181”相匹配的价格&库存,您可以联系我们找货
