COM-10917
COM-10917
    SPARKFUNELECTRONICS
    EXCITER 8 OHM 1W
COM-10917 数据手册
  Surface Transducer - Small COM-10917 Description: Surface transducers give you the awesome power to turn almost any surface into a speaker. Much like our larger surface transducer, this is essentially just a speaker except instead of a cone, the coil is attached to a pad that conducts the vibration into whatever you press it against. You can hook it up to an audio source and press it against the nearest table, wall or cardboard box. You can even put it against your head and play music directly into your skull (the ultimate surround sound). Note: The connectors on these units are somewhat fragile so take care to prevent stressing your connection to the unit. Dimensions: 21.5 x 14.5 x 7.9mm Features:        Impedance: 8±5% Ohm Resonant Frequency: 16 +/- 0.5 kHz Max Operating Voltage: 12 Vpp Frequency Response: 300-19000 Hz Rated input: 1.0 W Maximum input: 2.0 W Operating Temperature: -20 to +60 °C        https://www.sparkfun.com/products/10917 5‐25‐17
COM-10917 价格&库存
很抱歉,暂时无法提供与“COM-10917”相匹配的价格&库存,您可以联系我们找货
