COM-11192
COM-11192
    SPARKFUNELECTRONICS
    FOOT PEDAL SWITCH
COM-11192 数据手册
    Foot Pedal Switch COM-11192 Description: Put the pedal to the metal with this metal foot switch. This is the same kind of foot pedal you might find switching the power supply for a tattoo machine or as a sustain pedal on an electric piano. The non-slip pad on top and rubber bumpers on the bottom keep the pedal from slipping out of place during use. If you open it up, it’s a simple momentary switch and a big spring and that’s about it. This pedal has, however, been described as “luxuriant, elegant and generous” and I guess we’d have to agree. The 59 inch cable is terminated with a ¼" mono jack making it easy to incorporate into your next build, sounds “elegant” to us. Dimensions: 10.5 x 7 x 3 cm        https://www.sparkfun.com/products/11192 5‐25‐17
COM-11192 价格&库存
很抱歉,暂时无法提供与“COM-11192”相匹配的价格&库存,您可以联系我们找货
