COM-11273
COM-11273
    SPARKFUNELECTRONICS
    SWITCH PUSHBUTTON SPDT YELLOW
COM-11273 数据手册
  Big Dome Pushbutton - Yellow COM -1 1273 Description: It’s the end of the world, and you need a button to press. This is it. A 100mm diameter (outside diameter) dome illuminated push button comes with an LED, securing nut and a pre-installed long life horizontal microswitch. Button can also be adjusted to a low profile button by removing the middle ring. Features: • • • • • • LED indicator light runs at 12VDC Bulb holder is easy to install or remove 3 Terminals Button Actuator microswitch included Microswitch reliability tested to 10,000,000 cycles Microswitch can be replaced Polycarbonate lens cap for optical clarity Dimensions: • 100 mm Diameter x 72 mm Height • Net weight: 100grams • Mounting hole diameter: 24 mm https://www.sparkfun.com/products/11273 3/14/2017
COM-11273 价格&库存
很抱歉,暂时无法提供与“COM-11273”相匹配的价格&库存,您可以联系我们找货
