Circuit Scribe Maker Kit
COM-13255 RoHS Open Source Hardware
Description: This is the Circuit Scribe Maker Kit, a massive conductive ink pack with a full range of
modules and other items that you can use to create cool circuits. Similar to the Lite Kit, this Circuit
Scribe Maker Kit is easy to set-up, choose the modules you want to connect, draw your circuit lines
with the included Conductive Ink pen and you’re good to go! With this kit you will be able to work
with more advanced output components and sensors. Add sound to your circuits using the Buzzer
Module, fade between colors by combining the RGB LED and Potentiometer Modules, or control
your outputs with light using the Photosensor. Of course you don’t need to just stop at using only the
modules included in this kit, go out there and make any circuit you wish to create!
With Circuit Scribe you can draw exactly what you want, no wires or breadboard required. You can
build a circuit with nothing but a coin battery, paper clip, and LED, or build out complex circuits with
multiple components. The Conductive Ink Pen included in this kit uses a non toxic, silver conductive
ink that writes on any surface a regular roller ball pen would with a resistance of 2-10 Ohms/cm. This
kit also comes with a workbook full of great project ideas, 11 magnetic electric modules, a 9V
battery, and a few other accessories to add to your circuits.
Includes:
1x Conductive Ink Pen
1x 9V Battery
1x 9V Adapter Module
1x NPN Transistor Module
1x 2-Pin Module
1x Blinker Module
1x Potentiometer Module
1x Photo Sensor Module
1x SPST Switch Module
1x Buzzer Module
1x RGB LED Module
2x Bi-LED Module
1x Circuit Stencil
1x Sheet of Jumper Stickers
1x Steel Sheet
1x Workbook + Sketchbook
1x Mini Photo Resistor
1x 100 Ohm Resistor - ¼ Watt, 5% Tolerance
1x 1k Ohm Resistor - ¼ Watt, 5% Tolerance
1x 10K Ohm Resistor - ¼ Watt, 5% Tolerance
1x 100k Ohm Resistor - ¼ Watt, 5% Tolerance
1x 1M Ohm Resistor - ¼ Watt, 5% Tolerance
1x Capacitor 100nF
1x Capacitor 1.0uF
Features:
11 Magnetic Electric Modules
Guidebook with clear and defined how-to steps
Ink Resistance: 2-10 Ohms/cm
Pen Line Width: 0.4mm
Squeeze-Free Pen
https://www.sparkfun.com/products/13255 6‐21‐17
很抱歉,暂时无法提供与“COM-13255”相匹配的价格&库存,您可以联系我们找货
