COM-14360
COM-14360
    SPARKFUNELECTRONICS
    ADDRESS LED MODULE
COM-14360 数据手册
    SparkFun Lumenati 3x3 COM-14360 Open Source Hardware DESCRIPTION Designed to give your projects an edge in their lighting capacity, the SparkFun Lumenati 3x3 is a small, rectangular board equipped with nine APA102C LEDs arranged in a 3x3 array. The 3x3 board can be daisy-chained with other Lumenati boards, allowing for multiple design options and formations. With the equipped 0.1" spaced pins, this Lumenati can also be installed into a breadboard for more prototyping applications. Additionally, we have labeled the APA102C LEDs on each board with numbers indicating their position in the sequence to help you write code more easily. We especially love using the Lumenati boards to give our flying race drones a bit of style and panache. The APA102C addressable LEDs operate on +5V power input, as well as 0–5V logic levels for clock and data and employ a 2-wire communication protocol consisting of a clock line and a data line. While this requires one more wire than standard WS2812B LEDs, the advantage is that the communication with the LEDs becomes somewhat timing-independent, allowing you to run these directly off of a Raspberry Pi or other single-board computer that doesn’t normally allow for a long, precisely timed data stream without the use of additional hardware. FEATURES   Dimensions: 34.7mm x 23.3mm x 3.2mm (1.4" x 0.9" x 0.12") Weight: 3.35g Notice. This product requires other products in order to function properly. See essential products. Essentials SparkFun SAMD21 Mini Breakout                                                  DEV-13664 SparkFun Logic Level Converter ‐ Bi‐Directional                          BOB-12009 Wall Adapter Power Supply ‐ 5.1V DC 2.5A (USB Micro‐B)        TOL-13831 Soldering Iron ‐ 30W (EU, 230VAC)                                                 TOL-11650  https://www.sparkfun.com/products/14360 10-17-17
COM-14360 价格&库存
很抱歉,暂时无法提供与“COM-14360”相匹配的价格&库存,您可以联系我们找货
