COM-14555
COM-14555
    SPARKFUNELECTRONICS
    ADDRESS LED STRIP SERIAL RGB 2M
COM-14555 数据手册
      LED Neon Flex Rope COM-14555 This Neon Flex Rope is a 2m long (~6.5 feet), LED strip that simulates the neon effects you see in storefronts at night. Each rope is packed with sixty 5050 RGB LEDs (30 LEDs/m). Though this flexible LED rope does not actually utilize any neon gas, the waterproof (IP65) silicon housing provides a diffused glow similar to those “Open” signs. Each of these strips needs a 24VDC supply and includes all the connectors and mounting parts you need. You will be able to control the whole LED RGB rope to achieve cool lighting effects for outdoor and indoor uses including in hallways and stairs, holiday lighting and more! INCLUDES     1x LED Neon Flex Rope 1x Female Bare Wire Connector 4x Aluminum Mounting Clip FEATURES      Operating Voltage: 24VDC 30 RGB 5050 LEDs/m Waterproof Rating: IP65 Dimensions: 2000mm Long x 25.5mm Tall x 14mm Wide         https://www.sparkfun.com/products/14555 2-26-18
COM-14555 价格&库存
很抱歉,暂时无法提供与“COM-14555”相匹配的价格&库存,您可以联系我们找货
