COM-14612
COM-14612
    SPARKFUNELECTRONICS
    ADDRESS LED STRIP SERIAL RGBW 1M
COM-14612 数据手册
          Skinny LED RGBW Strip - Addressable, 1m, 60LEDs (SK6812) COM-14612   These are skinny addressable 1-meter-long 5V RGBW LED strips that come packed with 60 SK6812s. SK6812 LEDs are very similar to WS2812s with a few caveats: SK6812s add a white LED to the classic RGB mixture allowing you to provide new varieties of color to your project! As these are bare LED strips that have no protective coating, your project won’t be water proof but there is access to each SK6812 LED and each strip length can be easily modified to fit the length you need. You will be able to control each LED RGB individually, giving you the ability to create cool lighting effects for your car or perhaps under-cabinet lighting in your kitchen! Note: These come in 1m segments on a reel. They are preterminated with 0.1" spaced 3-pin connectors, as shown in the pictures. FEATURES            Operating Voltage: 5VDC Current: 50mA @ full brightness Beam Angle: 140 deg. Consumption Watts: 12±W/m Pixel Pitch: 16.7mm LED Quantity: 60 pcs 800KHz Protocol PCB Thickness: 5mm wide, 0.25mm thickness 3-pin JST-SM connector 3M Adhesive Tape on Back                                                   https://www.sparkfun.com/products/14612 4‐16‐18
COM-14612 价格&库存
很抱歉,暂时无法提供与“COM-14612”相匹配的价格&库存,您可以联系我们找货
