SmartiPi Touch Back Cover (Large)
COM-14572
Description
Here is a large cover to protect all of the HATs that you want to go onto the Raspberry Pi that you
have attached to your SmartiPi Touch. This easy-to-install back cover screws into the back VESA
mounts on the SmartiPi Touch with the four included screws. The cover allows you to protect HAT
boards and other electronic components that you might want for your project. Each is made out of
ABS plastic and can be easily cut, drilled or otherwise modified for any application or use.
Additionally, the cover helps protect the ethernet and USB ports on the Pi B+, 2 and 3.
The large SmartiPi Touch Back Cover is 37mm deep and allows for an additional 114mm of space
not reserved for your HATs.
Note: The SmartiPi Touch Back Cover does NOT include a SmartiPi Touch, LCD, camera,
很抱歉,暂时无法提供与“COM-14572”相匹配的价格&库存,您可以联系我们找货
