RGB LED Matrix Panel - 32x32
COM-14646
Are you looking to add a lot of color to your project? These massive 32x32 RGB LED panels are an
awesome place to start. You can create animations, games, or all sorts of other fun displays with
them. Yes, you read that right: a 32x32 LED matrix, that’s 1024 LEDs on a 7.5" x 7.5" board. On top
of all that, thanks to two IDC connectors, and a seamless frame, these panels can be daisy chained
together to form even bigger LED displays.
These panels require a regulated 3.3-5V supply for power which needs to be able to source a good
amount of current – up to 2A in the worst case. Included with each panel is a 0.15" pitch 4-pin
polarized connector power cable which is terminated with both a female polarized connector, and a
pair of spade terminals. Needless to say, if you are looking for a large, cheap, and easy to use RGB
LED matrix you’ve come to the right place.
Note: These displays were intended for use with FPGAs and high-speed processors. We’ve found
that 16MHz is about the slowest processor that can drive these adequately. If you want to daisychain them together, you will need more speed and more RAM.
INCLUDES
1x 32x32 RGB LED Panel
1x 0.15" Pitch 4-pin Power Cable w/ Spade Connectors
1x 16-pin (2x8) Ribbon Cables
FEATURES
1024 RGB LEDs
1/16 Scan Rate
Dual IDC Connectors for Daisy Chaining
3.3-5V Supply Voltage
https://www.sparkfun.com/products/14646 3‐19‐18
很抱歉,暂时无法提供与“COM-14646”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+915.23520
- 200+365.19120
- 500+352.98720
- 1000+346.96080
