COM-14662
COM-14662
    SPARKFUNELECTRONICS
    小键盘开关 12 聚合物 钥匙 传导橡胶 触点 矩阵 输出 不发光
COM-14662 数据手册
      Keypad - 12 Button COM-14662 This is a basic 12 button keypad that has been designed for easy user input and functionality. The buttons are set up in a matrix format. This allows a microcontroller to ‘scan’ the 7 output pins to see which of the 12 buttons is being pressed. Each of the keypad’s 12 buttons has been labeled 1, 2, 3, 4, 5, 6, 7, 8, 9, 0, *, and # and has been formatted to into the same layout as a telephone keypad with each keypress resistance ranging between 10 and 150 Ohms. We’ve also made sure to create an updated pin-out for this keypad since it has been changed from the previous version. The pin-out can be found in the Documents tab above                                                     https://www.sparkfun.com/products/14662 4‐30‐18
COM-14662 价格&库存
很抱歉,暂时无法提供与“COM-14662”相匹配的价格&库存,您可以联系我们找货
