COM-14698
COM-14698
    SPARKFUNELECTRONICS
    BENDABLE EL WIRE GREEN 3M
COM-14698 数据手册
        Bendable EL Wire - Green 3m COM-14698   Do you love EL wire but wish it was more bendable? Well look no further! This EL Wire contains a special bendable wire core that allows you to articulate and mold your EL wire any way that you want! EL wire, or electroluminescent wire, is a flexible wire coated in phosphor. Apply the appropriate voltage and it lights up! It looks a lot like a thin flexible neon tube. The bendable wire runs alongside the phosphor wire, making the product nearly twice the thickness of the non-bendable variety. They come in a variety of colors and can be driven pretty easily with an inverter. This particular wire glows with a green hue and is 3m (almost 10 feet) in length, approximately 5mm in diameter and is terminated with a simple JST-PH connector. This connector works directly with our SparkFun Original EL driver boards, the EL Escudo and the EL Sequencer.                                                 https://www.sparkfun.com/products/14698 7‐16‐18
COM-14698 价格&库存
很抱歉,暂时无法提供与“COM-14698”相匹配的价格&库存,您可以联系我们找货
