Mi-Light RGBW LED Controller Box
COM-14710 ROHS
The Mi-Light RGBW LED Controller Box is a 2.4GHz RF controllable LED accessory that enables
your non-addressable LED strips to change color, dim, and select pre-loaded modes via the Mi-Light
Remote Control (sold separately). Essentially, this little plastic box enables any non-WS2812 or
APA102 (“NeoPixel” or “DotStar”) LED strips to act as if they were without any other external boards.
Set up is simple thanks to an array of screw terminals on either side of the controller box. By just
screwing an LED strip’s control wires into the right side of this box and then plugging in power via a
barrel jack (or another set of screw terminals) on the left side of the box, you’ll be up and running in
no time!
Each Mi-Light RGBW LED Controller Box has a range of about 30m (almost 100ft) and an operating
voltage of 12VDC-24VDC with an output of 6A per channel. You will even have access to nine preset programs that the controller box can begin interacting with your LEDs out of the box. With these
capabilities, the LED controller box can manage any of the non-addressable LED strips we carry in
our catalog!
FEATURES
Transmission Frequency: 2.4GHz
Operating Voltage: 12VDC-24VDC
6A Load per Channel
Common Anode Output Connection
30 Meter Distance
Nine Pre-Set Programs
Dimensions: 85mm x 45mm x 23mm
https://www.sparkfun.com/products/14710 7-3-18
很抱歉,暂时无法提供与“COM-14710”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+306.52560
- 200+122.31000
- 500+118.22760
- 1000+116.20800
