COM-14966
COM-14966
    SPARKFUNELECTRONICS
    可寻址照明 - 40 LED 环形 串行 红色,绿色,蓝色(RGB) 50.80mm 直径
COM-14966 数据手册
  SparkFun LuMini LED Ring - 2 Inch (40 x APA102-2020) COM-14966 This is the two inch version of the SparkFun LuMini LED Ring, packed with 40 individually addressable LEDs, each capable of producing 16 million colors, it provides you with a lot of color for just about any reason! LuMini is a miniaturized version of our Lumenati LED line but instead of utilizing 5mm by 5mm APA102 LEDs (APA102-5050), LuMini uses a 2mm by 2mm package (APA102-2020). This allows for incredibly tight pixel densities, and thus, a more continuous ring of color for you to use! The LuMini LED Ring is powered and controlled using a few solder pads on the back of each board. These pads include 5V and ground, a set of pads for data and clock input, and another set for data and clock output. Since the ring acts like a string of LEDs, you’ll find multiple numbers silked onto the back of the board that correspond to the LED number in the above. The last handy feature we’ve equipped the LuMini LED Ring with is eight detachable mounting points (four inside the ring and four outside) that can be used to secure your ring to a surface/project or be broken off to make more complex designs. Note: In larger installations you may need to add a decoupling capacitor between power and ground to prevent voltage dips when turning on a whole bunch of LED’s simultaneously. We recommend using a 4.7µF capacitor which we sell in strips of 10. FEATURES      2in Diameter 40x APA102-2020 LEDs 8x Detachable Mounting Points Optional Capacitor Space Daisy-Chainable                                             https://www.sparkfun.com/products/14966/1‐21‐19
COM-14966
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出等。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现多路信号的切换,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、医疗、工业控制等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
COM-14966 价格&库存
很抱歉,暂时无法提供与“COM-14966”相匹配的价格&库存,您可以联系我们找货
