SparkFun Qwiic Single Relay
COM-15093
Have you ever wanted to control something powerful or have you ever needed to turn on/off a high
power device from your Arduino or another low powered microcontroller? The SparkFun Qwiic
Single Relay provides you with the easiest to use relay yet. The Single Relay board can handle up to
5.5A at 240VAC for long periods of time and allows you to control large power loads with simple I2C
commands. Utilizing our handy Qwiic system, and on-board screw terminals, no soldering is required
to connect it to the rest of your system!
The Qwiic Relay comes with a default I2C address of 0x18 but can be changed with a simple
command allowing you to control over 100 Qwiic Relays on a single bus (but please be aware that
toggling lots of relays on a 3.3V bus can cause voltage spikes so an external power supply will be
required)! In addition, there is an address jumper on the back of the board. Closing this jumper with
solder will change the address to 0x19.
We’ve included many safety precautions onto the PCB including, ground isolation between the load
and the low voltage control has been increased and an air-gap has been added around the common
pin. The traces between the relay and the NC/NO/COM terminals have been doubled to increase the
maximum current. But if you aren’t comfortable playing with high voltage AC, that’s understandable.
Please consider using the IoT Power Relay, instead. It’s not I2C supported but the IoT Power Relay
contains shielding to prevent accidental shock and is great for learning how to use relay power
accessories.
The SparkFun Qwiic Connect System is an ecosystem of I2C sensors, actuators, shields and cables
that make prototyping faster and less prone to error. All Qwiic-enabled boards use a common 1mm
pitch, 4-pin JST connector. This reduces the amount of required PCB space, and polarized
connections mean you can’t hook it up wrong.
FEATURES
Operating Voltage: 1.7V-3.6V
Coil Resistance: 23.5Ω
I2C Address: 0x18 (Default), (Jumper changes to 0x19)
Max Current (Through Relay): 5.5A (240 VAC)
https://www.sparkfun.com/products/15093.1‐21‐19
很抱歉,暂时无法提供与“COM-15093”相匹配的价格&库存,您可以联系我们找货
