COM-15208
COM-15208
    SPARKFUNELECTRONICS
    TPS63070 - DC/DC,步升/步降 1,非隔离 输出评估板
COM-15208 数据手册
      SparkFun Buck-Boost Converter COM-15208   The SparkFun Buck-Boost Converter is a handy power accessory board that allows you to fine tune the amount of power your project receives. This converter can take an input voltage of anywhere from 3-16V which can then be regulated to an output voltage between 2.5-9V. With the switch on the bottom of the board, you can set the common output voltages of 3.3V and 5V, but we've also added a custom setting that allows you to solder a resistor based on your custom voltage needs. The GPIO pins have also been broken out along the top of the board for even more control! In addition to the voltage control, the SparkFun Buck-Boost Converter uses a switching DC/DC converter, which is more efficient than a linear regulator. More efficiency means less energy is wasted in the form of heat. With built-in overtemperature protection and an optional heatsink, you can achieve up to 95% efficiency rating.   FEATURES          Input voltage range of 3-16V Output voltage adjustable from 2.5-9V Three selectable output voltages: 3.3V, 5V, or custom GPIO broken out for additional control Operating die temperature range of -40 to +125°C Optional Heatsink Up to 95% Efficiency Overtemperature Protection                     https://www.sparkfun.com/products/15208/5‐14‐9
COM-15208 价格&库存
很抱歉,暂时无法提供与“COM-15208”相匹配的价格&库存,您可以联系我们找货
