COM-15290
COM-15290
    SPARKFUNELECTRONICS
    ATtiny84 小键盘 人机接口 Qwiic 平台评估扩展板
COM-15290 数据手册
SparkFun Qwiic Keypad - 12 Button COM-15290 Keypads are very handy input devices, but who wants to tie up seven GPIO pins, wire up a handful of pull-up resistors, and write firmware that wastes valuable processing time scanning the keys for inputs? The SparkFun Qwiic Keypad comes fully assembled and makes the development process for adding a 12 button keypad easy. No voltage translation or figuring out which I2C pin is SDA or SCL, just plug and go! Utilizing our handy Qwiic system, no soldering is required to connect it to the rest of your system. However, we still have broken out 0.1"-spaced pins in case you prefer to use a breadboard. Each of the keypad's 12 buttons has been labeled 1, 2, 3, 4, 5, 6, 7, 8, 9, 0, *, and # and has been formatted to into the same layout as a telephone keypad with each keypress resistance ranging between 10 and 150 Ohms. The Qwiic Keypad reads and stores the last 15 button presses in a First-In, First-Out (FIFO) stack, so you don’t need to constantly poll the keypad from your microcontroller. This information, then, is accessible through the Qwiic interface. The SparkFun Qwiic Keypad even has a software configurable I2C address so you can have multiple I2C devices on the same bus. The SparkFun Qwiic connect system is an ecosystem of I2C sensors, actuators, shields and cables that make prototyping faster and less prone to error. All Qwiic-enabled boards use a common 1mm pitch, 4-pin JST connector. This reduces the amount of required PCB space, and polarized connections mean you can’t hook it up wrong. FEATURES      Software Selectable Slave Address Low Power ATtiny85 controller Button Presses w/ Time Stamp Default I2C Address: 0x4B 2x Qwiic Connector                                                  https://www.sparkfun.com/products/15290/5‐6‐19
COM-15290 价格&库存
很抱歉,暂时无法提供与“COM-15290”相匹配的价格&库存,您可以联系我们找货
