COM-15337
COM-15337
    SPARKFUNELECTRONICS
    TRRS AUDIO PLUG - 3.5MM (METAL)
COM-15337 数据手册
      TRRS Audio Plug - 3.5mm (Metal) COM-15337 ROHS TRRS connectors are the audio-style connectors that you see on some phones, MP3 players and development boards. TRRS stands for "Tip, Ring, Ring, Sleeve," which reflects the fact that, unlike a standard stereo connector, this actually has three conductors and a ground. Some devices use the extra conductor for a microphone (like hands-free headsets) or to carry a video signal (like in some MP3/MP4 players). If you're hacking on something that has a 4-conductor audio jack, being able to plug straight in will keep your build clean and simple. Note: This plug allows you to add a custom length of wire to your connector or repair a broken shroud on an existing cable you just cannot live without. Unfortunately, the supplier has not provided a datasheet or dimensional drawing please see the similar documents provided by other SparkFun products on the "documents" tab. INCLUDES   Plug w/ solder-point connections Shroud to cover solder connections            https://www.sparkfun.com/products/15337/7‐22‐19
COM-15337 价格&库存
很抱歉,暂时无法提供与“COM-15337”相匹配的价格&库存,您可以联系我们找货
