COM-15438
COM-15438
    SPARKFUNELECTRONICS
    TRS AUDIO PLUG - 3.5MM (METAL)
COM-15438 数据手册
  TRS Audio Plug - 3.5mm (Metal) COM-15438 TRS connectors are the audio-style connectors that you see on some phones, MP3 players and development boards. TRS stands for "Tip, Ring, Sleeve." If you're hacking on something that has a three-conductor audio jack, being able to plug straight in will keep your build clean and simple. Note: This plug allows you to add a custom length of wire to your connector or repair a broken shroud on an existing cable you just cannot live without. Unfortunately, the supplier has not provided a datasheet or dimensional drawing please see the similar documents provided by other SparkFun products on the "documents" tab. INCLUDES   Plug w/ solder-point connections Shroud to cover solder connections        https://www.sparkfun.com/products/15438 /7‐22‐19
COM-15438 价格&库存
很抱歉,暂时无法提供与“COM-15438”相匹配的价格&库存,您可以联系我们找货
