COM-15486
COM-15486
    SPARKFUNELECTRONICS
    RV-3028 实时时钟(RTC) 时钟定时 micro:bit 平台评估扩展板
COM-15486 数据手册
    SparkFun gator:RTC - micro:bit Accessory Board COM-15486 The gator:RTC is a supplemental data logging tool to be used in conjunction with the gator:log, part of SparkFun's gator:bit series of gator-clippable accessories designed for easy interface with the micro:bit or other microcontrollers. This tool allows a student to focus more on the experiment than watching a thermometer or stopwatch. At its core is a RV-3028 real time clock (RTC) module from Micro Crystal, using a convenient I²C bus interface. The module enables you to track the year, month, date, weekday, hours, minutes, and seconds. It also includes an external event input with a handy time stamp function. It is extremely low power, running at about 40-60nA at 3V. The gator:RTC provides four pads for power and data and a built-in, rechargeable 3V lithium coin cell battery. The micro:bit is a pocket-sized computer that lets you get creative with digital technology. Between the micro:bit and our shield-like bit boards you can do almost anything while coding, customizing and controlling your micro:bit from almost anywhere! You can use your micro:bit for all sorts of unique creations, from robots to musical instruments and more. At half the size of a credit card, this versatile board has vast potential!   FEATURES    RV-3028 RTC module o I²C bus interface o Tracks year, month, date, weekday, hours, minutes, and seconds o External event input with time stamp function o Low power: 40-60nA at 3V Four pads for power and data Rechargeable 3V lithium coin cell battery   https://www.sparkfun.com/products/15486/9‐12‐19
COM-15486 价格&库存
很抱歉,暂时无法提供与“COM-15486”相匹配的价格&库存,您可以联系我们找货
