DEV-11649
DEV-11649
    SPARKFUNELECTRONICS
    DANGER SHIELD
DEV-11649 数据手册
    SparkFun Danger Shield DEV-11649 RoHS     Description: The SparkFun Danger Shield mounts on top of your Arduino or Arduino Pro and equips it with a variety of fun and useful inputs and outputs. The Danger Shield has so much potential; we can’t wait to see what you’re able to do with it! The shield’s features include:        Three linear slide potentiometers connected to the Arduino’s analog pins 0 through 2. Red and yellow LEDs connected to digital pins 5 and 6 - PWM pins - so you can easily vary their brightness. Three momentary push buttons connected up to the Arduino’s digital pins 10 through 12. Those lines will go low when the buttons are pressed. A photocell and a temperature sensor, both with analog outputs, are connected to the analog pins 3 and 4, respectively. An 8-bit shift register set up to control a blue 7-segment LED. A buzzer - so you can get sound out of your Arduino Capacitive Touch pad - Using the CapSense library to sense touch. This product comes as a kit of parts, which you’ll have to solder into the included PCB. All parts are through-hole so it should go together relatively easily; but always check your component orientation before soldering! Kit Includes:                 1x PCB Danger Shield Kit 3x Slide Potentiometers - 10K 1x 7-Segment LED - Blue 1x 8-bit Shift Register - 74HC595 1x Temperature Sensor - TMP36 1x Miniature Photocell 1x Piezo Speaker 1x Basic LED - Red 2x Basic LEDs - Yellow 1x Mini Push Button 3x Momentary Push Buttons - 12mm Square 11x Resistors - 330 Ohm 1x Resistors - 10K Ohm 1x Resistor 1M Ohm 1/6W 2x 8-pin Arduino Stackable Headers 2x 6-pin Arduino Stackable Headers        https://www.sparkfun.com/products/11649 5‐16‐17
DEV-11649 价格&库存
很抱歉,暂时无法提供与“DEV-11649”相匹配的价格&库存,您可以联系我们找货
