DEV-13714
DEV-13714
    SPARKFUNELECTRONICS
    FREESOC2 PSOC 5LP EVAL BRD
DEV-13714 数据手册
FreeSoC2 Development Board - PSoC5LP DEV- 137 1 4 ROHS This is the FreeSoC2 Development Board, SparkFun’s take on the PSoC5LP ARM Cortex. The PSoC (Programmable System-on-Chip) brings together features of the programmable devices and microcontroller-type systems-on-chips into one package. By placing a programmable fabric between the peripherals and the pins, the FreeSoC2 allows any function to be routed to any pin! Moreover, the onboard PSoC includes a number of programmable blocks, which allow the user to define arbitrary digital and analog circuits for their specific application. SparkFun’s FreeSoC2 board has two processors onboard: a CY8C5868LTI-LP039 and a CY8C5888AXI-LP096. The former serves as a debugger/programmer for the latter, which is the target upon which your application code will be installed. Both parts contain a Cortex-M3 processor core, 256kB of flash memory, 64kB of SRAM and 2kB of EEPROM. The only significant differences between the two are package size and clock speed. The target is in a TQFP-100 package, which provides 72 I/O pins versus the debugger’s QFN-68 package and 48 I/O pins, and the target can operate at 80MHz versus the debugger’s 67MHz limit. Additionally, the FreeSoC2 can support 5V and 3.3V I/O voltages. With a simple upload of new firmware, the Arduino core has been ported to the PSoC5LP, so you can write code for the board in the standard Arduino IDE. The board duplicates the functionality of an Arduino Uno R3’s various hardware peripherals on the pins, so many examples, libraries and shields will work on this board. However, to get the most out of the device, you will need to use the PSoC Creator IDE (which is free of charge with no code limits from Cypress Semiconductor). Please keep in mind that the PSoC Creator software is Windows-only at this time. Note: The FreeSoC2 Develpment Board is a collaboration with Jon Moeller. A portion of each sales goes back to him for product support and continued development. FEATURES • • • • • CY8C5868LTI-LP039 & CY8C5888AXI-LP096 Cortex-M3 Processor Cores 256kB of Flash Memory (each core) 64kB of SRAM (each core) 2kB of EEPROM (each core) Arduino Uno R3-type headers https://www.sparkfun.com/products/13714 11-20-18
DEV-13714 价格&库存
很抱歉,暂时无法提供与“DEV-13714”相匹配的价格&库存,您可以联系我们找货
