DEV-13735
DEV-13735
    SPARKFUNELECTRONICS
    LILYPAD RGB LED
DEV-13735 数据手册
      LilyPad RGB LED DEV-13735   Blink any color you need! Use the LilyPad RGB LED board as a simple indicator, or by pulsing the red, green, and blue channels, you can produce a broad variety of colors. Each of the colors in the RGB LED are connected to one of the sew tabs on the board labeled R, G, and B. The color channels on this RGB LED are all connected through a common cathode (negative) pin. We have updated our design to this configuration so that the individual red, green, and blue LEDs now share a common ground tab. To light up each color individual LED, connect them each to a power source. For simple circuit hookups, this means you need to connect the R, G, or B sew tabs to power (+) and in code set them to HIGH (for digital output) or 255 (for analog output) to turn them on. LilyPad is a wearable technology developed by Leah Buechley and cooperatively designed by Leah and SparkFun. Each LilyPad was creatively designed to have large connecting pads to allow them to be sewn into clothing. Various input, output, power, and sensor boards are available. They're even washable! Note: A portion of this sale is given back to Dr. Leah Buechley for continued development and education of e-textiles. FEATURES   20mm outer diameter Thin 0.8mm PCB       https://www.sparkfun.com/products/13735 /7‐22‐19
DEV-13735 价格&库存
很抱歉,暂时无法提供与“DEV-13735”相匹配的价格&库存,您可以联系我们找货
