DEV-13955
DEV-13955
    SPARKFUNELECTRONICS
    ATMega328 数据记录器 存储器 评估板
DEV-13955 数据手册
    SparkFun OpenLog with Headers DEV-13955 The SparkFun OpenLog with Headers is an open source data logger that works over a simple serial connection and supports microSD cards up to 64GB. The OpenLog can store or "log" huge amounts of serial data and act as a black box of sorts to store all the serial data that your project generates, for scientific or debugging purposes. This version of th OpenLog even includes pre-soldered headers for your convenience. The SparkFun OpenLog uses an ATmega328 running at 16MHz thanks to the onboard resonator. The OpenLog draws approximately 2-3mA in idle (nothing to record) mode. During a full record OpenLog can draw 10 to 20mA depending on the microSD card being used. All data logged by the OpenLog is stored on the microSD card. Any 512MB to 32GB microSD card should work. OpenLog supports both FAT16 and FAT32 SD formats. FEATURES          VCC Input: 3.3V-12V (Recommended 3.3V-5V) Log to low-cost microSD FAT16/32 cards up to 32GB Simple command interface Configurable baud rates (up to 115200bps) Preprogrammed ATmega328 and bootloader Four SPI pogo pins Two LEDs indicate writing status 2mA idle, 6mA at maximum recording rate Pre-soldered Headers     https://www.sparkfun.com/products/13955/1‐29‐20
DEV-13955 价格&库存
很抱歉,暂时无法提供与“DEV-13955”相匹配的价格&库存,您可以联系我们找货
DEV-13955
库存:500
