DEV-14215
DEV-14215
    SPARKFUNELECTRONICS
    按钮 人机接口 micro:bit 平台评估扩展板
DEV-14215 数据手册
  SparkFun gamer:bit DEV-14215 Description: The SparkFun gamer:bit is a fun-filled “carrier” board for the micro:bit that, when combined with the micro:bit, provides you with a fully functional game system. Designed in a similar form factor to the classic Nintendo NES controller, the gamer:bit is equipped with a four-direction “Dpad” on the left side of the board and two action buttons on the right side of the board. The two push buttons on the micro:bit in the center function as start and select. The gamer:bit connects to the micro:bit via an edge connector in the center of the board, making setup easy. This creates a handy way to swap out micro:bits for programming, while still providing reliable connections to all of the different pins on the micro:bit. We have also included several poke home connectors on the back of the board that correspond to each button on the gamer:bit, allowing you to use external parts to control your game! The micro:bit is a pocket-sized computer that lets you get creative with digital technology. Between the micro:bit and our shield-like bit boards you can do almost anything while coding, customizing and controlling your micro:bit from almost anywhere! You can use your micro:bit for all sorts of unique creations, from robots to musical instruments and more. At half the size of a credit card, this versatile board has vast potential! Note: The SparkFun gamer:bit is available to pre-order and does NOT include a micro:bit board; we expect to start shipping units by early July. Adding a pre-order product to an order may cause a delay. Be sure to uncheck “ship complete order” in your cart to avoid delays in shipping in-stock items Features:      Edge connector for ease of use with the micro:bit Full direction “D-pad” Two action buttons NES controller style Poke home connectors for external inputs (i.e., arcade joystick and buttons)                                                 https://www.sparkfun.com/products/14215 6‐26‐17
DEV-14215 价格&库存
很抱歉,暂时无法提供与“DEV-14215”相匹配的价格&库存,您可以联系我们找货
