DEV-14278
DEV-14278
    SPARKFUNELECTRONICS
    STEMTERA BLUE ATMEGA16U2/328P
DEV-14278 数据手册
  STEMTera (Blue) DEV-14278 RoHS Description: The STEMTera is an innovation in breadboard history. It is the first breadboard with an Arduino-compatible hardware suite built in that works with thousands of shields. With ATmega16U2/32U2 pins exposed, native USB projects can be easily developed using the LUFA framework. The STEMTera also features a LEGO® brick-compatible bottom that empowers projects to be built beyond imagination. This version of the STEMTera is housed in a durable blue ABS plastic enclosure. Since the STEMTera is a development board built directly into a breadboard, it eliminates the need for messy wires to be strewn about your work space. Having two microcontrollers built inside the breadboard provides direct access to ATmega328P and ATmega16U2’s I/O pins. With the 21 I/O pins of the ATmega32U2 exposed, users will be able to develop native USB projects with ease. These extra I/O pins can work directly with the LUFA framework without having a middleman to translate messages, as with the original Arduino UNO. Additionally, the STEMTera is pin-to-pin compatible with an Arduino UNO R3 shield and supports multiple IDEs, including: Atmel® Studio, Arduino IDE, AVR-GCC, AVR-GCC with LUFA, Scratch and more! The STEMTera even has a LEGO-compatible 10x14 bottom cover that enables LEGO bricks to be connected directly into the breadboard without using special mounting techniques or adapters. Dimensions: 111.8mm x 79.8mm x 16.1mm Features:       Dual Microcontroller — ATmega328P & ATmega16U2 LEGO-Compatible Bottom Cover USB Native Development 4 LEDs (Power, TX, RX and L) Blue ABS Enclosure IDE Support o Atmel Studio o Arduino IDE o AVR-GCC o AVR-GCC with LUFA o Scratch                                                https://www.sparkfun.com/products/14278 6‐20‐17
DEV-14278 价格&库存
很抱歉,暂时无法提供与“DEV-14278”相匹配的价格&库存,您可以联系我们找货
