DEV-14346
DEV-14346
    SPARKFUNELECTRONICS
    可穿戴设备 ATmega32U4 MCU LilyPad ProtoSnap
DEV-14346 数据手册
    LilyPad ProtoSnap Plus DEV-14346 RoHS Open Source Hardware The LilyPad ProtoSnap Plus is a sewable electronics prototyping board that you can use to explore circuits and programming, then break apart to make an interactive fabric or wearable project. Programming the ProtoSnap Plus is easy with the free Arduino software you’ll need to program the ATmega32U4 on LilyPad USB Plus at the heart of the board. Once you’ve installed the software, you’ll be able to write and upload your own programs to the board, making it do almost anything you want. At the center of the ProtoSnap Plus is the LilyPad USB Plus microcontroller, pre-wired to a LilyPad board including a LilyPad Light Sensor, LilyPad Buzzer, LilyPad Button Board, four pairs of colored LilyPad LEDs and a LilyPad Slide Switch. Because these components are connected together on the ProtoSnap board, you can test out your project ideas before you sew. The ProtoSnap Plus also includes expansion ports that let you sew your wearables together or use alligator cables to easily connect external sensors and components. After testing out your coding ideas using the attached LilyPad pieces, you can break apart the prototyping board and sew them into your project! Note: A portion of this sale is given back to Dr. Leah Buechley for continued development and education in e-textiles. Included on the ProtoSnap           1x LilyPad USB Plus 1x LilyPad Light Sensor 1x LilyPad Buzzer 1x LilyPad Button 1x LilyPad Switch 2x LilyPad LED - Yellow 2x LilyPad LED - Red 2x LilyPad LED - Green 2x LilyPad LED - Blue 5x Expansion Ports                                              https://www.sparkfun.com/products/14346 10‐9‐17
DEV-14346 价格&库存
很抱歉,暂时无法提供与“DEV-14346”相匹配的价格&库存,您可以联系我们找货
