DEV-14495
DEV-14495
    SPARKFUNELECTRONICS
    分接板 连接性 Qwiic 平台评估扩展板
DEV-14495 数据手册
  SparkFun Qwiic Adapter  DEV-14495 RoHS Open Soure Hardware In Eagle Library The SparkFun Qwiic Adapter provides the perfect means to make any old I2C board into a Qwiicenabled board. This adapter breaks out the I2C pins from the Qwiic connectors to pins that you can easily solder with your favorite I2C-enabled device. The Qwiic Adapter has two Qwiic connection ports, all on the same I2C bus. Four plated through holes are broken out for SCL, SDA, 3.3V and GND. These pins can be used to convert an old I2Cenabled device into a Qwiic-enabled board. The SparkFun Qwiic Connect System is an ecosystem of I2C sensors, actuators, shields and cables that make prototyping faster and less prone to error. All Qwiic-enabled boards use a common 1mm pitch, 4-pin JST connector. This reduces the amount of required PCB space, and polarized connections mean you can’t hook it up wrong. FEATURES   2x Qwiic Connection Ports Broken-out I2C Pins https://www.sparkfun.com/products/14495 12-4-17
DEV-14495 价格&库存
很抱歉,暂时无法提供与“DEV-14495”相匹配的价格&库存,您可以联系我们找货
