DEV-14591
DEV-14591
    SPARKFUNELECTRONICS
    LOVE TO CODE CHIBI CHIP MICROCON
DEV-14591 数据手册
        Love to Code Chibi Chip Microcontroller Board DEV-14591   Interested in coding, but don’t know where to start? Or perhaps looking to add that personal, interactive touch to a craft project? The Love to Code (LTC) system from Chibitronics is designed to enable beginners of all backgrounds and ages to try out paper circuits and programming without the frustration of installing software. If you’ve browsed the web on your laptop, smartphone or tablet, and used headphones to listen to music, you know everything you need to get started! The Chibi Chip Microcontroller Board is the heart of the LTC system. You can use the Chibi Chip to bring life to your Chibi Lights LED stickers by making them blink and fade. Add interactivity to your greeting cards and projects by connecting switches and sensors to your Chibi Chip. You get to pick how to make the programs: either by dragging-and-dropping blocks together using Microsoft’s MakeCode Editor, or by writing Arduino-style computer code using Chibitronics’ Love to Code Editor. INCLUDES    1x Chibi Chip Microcontroller Board 1x Programming Cable        https://www.sparkfun.com/products/14591 4‐3‐18
DEV-14591
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路安全。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚发光二极管正极,4脚发光二极管负极,5脚光电晶体管集电极,6脚光电晶体管发射极。
4. 参数特性:EL817的主要参数包括正向电流为50mA,反向电压为5V,输入电流为10mA,输出电流为10mA。
5. 功能详解:EL817通过内部发光二极管和光电晶体管实现电-光-电转换,实现信号隔离。
6. 应用信息:EL817广泛应用于工业控制、仪器仪表、通信设备等领域。
7. 封装信息:EL817采用DIP6封装。
DEV-14591 价格&库存
很抱歉,暂时无法提供与“DEV-14591”相匹配的价格&库存,您可以联系我们找货
