LilyPad Light Sensor
DEV-14629 ROHS
The LilyPad Light Sensor is a sewable breakout board with an ALS-PT19 light sensor built in and
ready to use right away. Each sensor outputs voltage between 0V and 3.3V depending on the level
of ambient light shining on it. As more light is applied on the sensor, more current will flow from the
board through the signal tab to the microcontroller you connect the sensor to. If the sensor receives
no light, no current will flow through it. In a typical indoor lighting situation, the sensor will output
around 1 to 2V. Adding this board into your next e-textile or wearable project will really open up the
possibilities by being able to incorporate light level sensing capabilities.
LilyPad is a wearable e-textile technology developed by Leah Buechley and cooperatively designed
by Leah and SparkFun. Each LilyPad was creatively designed to have large connecting pads to
allow them to be sewn into clothing. Various input, output, power, and sensor boards are available.
They’re even washable!
Note: A portion of this sale is given back to Dr. Leah Buechley for continued development and
education of e-textiles.
FEATURES
20mm outer diameter
Thin 0.8mm PCB
https://www.sparkfun.com/products/14629 6‐11‐18
很抱歉,暂时无法提供与“DEV-14629”相匹配的价格&库存,您可以联系我们找货
