DEV-14747
DEV-14747
    SPARKFUNELECTRONICS
    Raspberry Pi - 编程器
DEV-14747 数据手册
    SparkFun Pi AVR Programmer HAT DEV-14747   The SparkFun Pi AVR Programmer HAT makes it easy to program AVRs directly from the SPI hardware pins on any Raspberry Pi. It was originally designed as an in-house solution for SparkFun production, but now is offered as a robust programming tool for anyone to purchase! This programmer is by far one of the fastest, most reliable, and hack-able (fully open sourced) AVR programming solutions available. Whether you’re a beginner or experienced electronics enthusiast, the Pi AVR Programmer HAT should be easy to get up-and-running. The SparkFun Pi AVR Programmer HAT plugs directly into the GPIO port on your Raspberry Pi and provides multiple unique amenities onboard including (but not limited to) a capacitive touch pad to engage programming, multiple Pass / Fail status LEDs, an isolation switch, and label boxes to keep track of your projects. Also included with each HAT is a 1x6 hookup cable that connects to the programmer’s ISP header, and an ISP interface adapter equipped with a 2x3 header. Programming an AVR through an in-system programmer (ISP) can provide many benefits including a faster code upload rate, the ability to overwrite the bootloader and gain a bit more flash space, and a way to influence the fuse bits to change a multitude of settings on your target. This HAT can be used directly from the command line using AVRDUDE commands, with some simple setup steps, or it can function as a stand-alone programmer with a capacitive touch pad engage button and status LEDs!   INCLUDES     1x SparkFun Pi AVR Programmer HAT 1x SparkFun Pi AVR Programmer Adapter 1x Jumper Wire - 0.1", 6-pin, 6"                                                     https://www.sparkfun.com/products/14747 7‐30‐18
DEV-14747 价格&库存
很抱歉,暂时无法提供与“DEV-14747”相匹配的价格&库存,您可以联系我们找货
