DEV-15794
DEV-15794
    SPARKFUNELECTRONICS
    Qwiic 转 Raspberry Pi 接口 Raspberry Pi 平台评估扩展板
DEV-15794 数据手册
      SparkFun Qwiic SHIM for Raspberry Pi DEV-15794   The SparkFun Qwiic SHIM for Raspberry Pi is a small, easily removable breakout that easily adds a Qwiic connector to your Raspberry Pi. The SHIM design allows you to plug directly to the Pi's I2C bus with no soldering required and the thin PCB design allows for it to be sandwiched on your Pi GPIO with other HATs! The Qwiic SHIM works great when you do not need the full capabilities of the Qwiic pHAT for Raspberry Pi or if you want to add a Qwiic connector to your Pi but do not have room for yet another HAT. The Qwiic SHIM uses a unique friction-based connector that wedges itself onto the GPIO header for a secure, solderless connection. As you would expect, it has a single Qwiic connector that connects to your Pi's I2C bus (SDA, SCL, 5V and Ground). The SHIM also has a 3.3V regulator so it will work with all Qwiic devices. Even better, the SparkFun Qwiic SHIM will also work with the NVIDIA Jetson Nano Developer Kit! The SparkFun Qwiic Connect System is an ecosystem of I2C sensors, actuators, shields and cables that make prototyping faster and less prone to error. All Qwiic-enabled boards use a common 1mm pitch, 4-pin JST connector. This reduces the amount of required PCB space, and polarized connections mean you can’t hook it up wrong. FEATURES      Small Form Factor HAT Stackable Fits inside Protective Case No Soldering Required Qwiic Connector       https://www.sparkfun.com/products/15794/12‐12‐19
DEV-15794 价格&库存
很抱歉,暂时无法提供与“DEV-15794”相匹配的价格&库存,您可以联系我们找货
