SparkFun GPS Breakout - XA1110 (Qwiic)
GPS-14414 RoHS Open Source Hardware
The SparkFun XA1110 GPS Breakout is a small I2C-supported module built for easy hookup, thanks
to our Qwiic Connect System. Equipped with the XA1110 GPS module from GTOP, this board
utilizes the MediaTek MT3333 chipset, loaded with specialized SparkFun firmware that enables both
I2C and serial ports simultaneously. Using I2C means you won’t have to tie up your serial port with
GPS, leaving it open to other possibilities.
This GPS Breakout supports up to 210 PRN channels with 99 search channels and 33 simultaneous
tracking channels. With support of GPS, GLONASS, QZSS, SBAS and more, the onboard XA1110
can provide even more accurate positioning in multiple locations. Additionally, the XA1110 GPS
Breakout is configured with an onboard RTC battery that enables a warm-start functionality, giving
the X1 just five seconds to first fix, as well as a U.FL connector that provides you the option to hook
up an external antenna via a U.FL cable.
The SparkFun Qwiic Connect System is an ecosystem of I2C sensors, actuators, shields and cables
that make prototyping faster and less prone to error. All Qwiic-enabled boards use a common 1mm
pitch, 4-pin JST connector. This reduces the amount of required PCB space, and polarized
connections mean you can’t hook it up wrong.
FEATURES
33 tracking/99 acquisition-channel GPS +GLONASS receiver
Supports QZSS & SBAS (WAAS, EGNOS, MSAS, GAGAN)
Sensitivity: -165dBm
Update Rate: up to 10Hz
12 multi-tone active interference canceler
2x Qwiic connectors
U.FL connector
Onboard RTC battery
Notice. This product requires other products in order to function properly.
See essential products.
Essentials
Qwiic Cable ‐ 100mm
PRT-14427
SparkFun Qwiic Shield for Arduino
DEV-14352
SparkFun RedBoard ‐ Programmed with Arduino
DEV-13975
https://www.sparkfun.com/products/14414 10‐23‐17
很抱歉,暂时无法提供与“GPS-14414”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+374.127501+47.65000
