GPS-15005
GPS-15005
    SPARKFUNELECTRONICS
    GPS RTK BOARD NEO-M8P-2 QWIIC
GPS-15005 数据手册
          SparkFun GPS-RTK Board - NEO-M8P-2 (Qwiic) GPS-15005 R O H S With GPS you are able to know where you are, where you’re going, and how to get there anywhere on Earth within 30 seconds. This means the higher the accuracy the better! GPS Real Time Kinematics (RTK) has mastered dialing in the accuracy on their GPS modules to 25mm, and that’s why we had to put it on this board! The SparkFun GPS-RTK Board is a powerful breakout board for the NEO-M8P-2 module from ublox. The NEO-M8P-2 is a top-of-the-line module for high accuracy GNSS and GPS location solutions including RTK. With this board, you will be able to know where you (or any object) are within one inch! The NEO-M8P-2 is unique in that it is capable of both rover and base station operations. Utilizing our handy Qwiic system, no soldering is required to connect it to the rest of your system. However, we still have broken out 0.1"-spaced pins in case you prefer to use a breadboard.     We’ve even included a rechargable backup battery to keep the latest module configuration and satellite data available for up to two weeks. This battery helps ‘warm-start’ the module decreasing the time-to-first-fix dramatically. This module features a survey-in mode allowing the module to become a base station and produce RTCM 3.x correction data (as opposed to the previous version of the module which is not able to produce RTCM data). The number of configuration options of the NEO-M8P-2 is incredible! Geofencing, variable I2C address, variable update rates, even the high precision RTK solution can be increased to 4Hz. The GPS-RTK even has four communications ports: USB (which enumerates as a COM port), UART (with 3.3V TTL), I2C (via the two Qwiic connnectors or broken out pins), and SPI. We’ve also written an Arduino library for u-blox modules to make reading and controlling the GPSRTK over our Qwiic Connect System easy. The SparkFun Qwiic Connect System is an ecosystem of I2C sensors, actuators, shields and cables that make prototyping faster and less prone to error. All Qwiic-enabled boards use a common 1mm pitch, 4-pin JST connector. This reduces the amount of required PCB space, and polarized connections mean you can’t hook it up wrong. FEATU RES             Voltage: 5V or 3.3V but all logic is 3.3V Current: ~35mA (varies with constellations and tracking state) Time to First Fix: 29s (cold), 1s (hot) Max Navigation Rate: o PVT (basic location over UBX binary protocol) - 10Hz o RTK - 5Hz o Moving Baseline RTK - 4Hz o Raw - 10Hz Horizontal Position Accuracy: o 2.5m without RTK o 0.025m with RTK 2x Qwiic Connectors Weight: 6.3g Dimensions: 40.6mm x 33mm (1.6in x 1.3in)                                                   https://www.sparkfun.com/products/15005 10‐24‐18
GPS-15005 价格&库存
很抱歉,暂时无法提供与“GPS-15005”相匹配的价格&库存,您可以联系我们找货
