KIT-15209
KIT-15209
    SPARKFUNELECTRONICS
    ATtiny84A,ID-12LA RFID 阅读器 RF Qwiic 平台评估扩展板
KIT-15209 数据手册
    SparkFun RFID Qwiic Kit  KIT‐15209  The SparkFun RFID Qwiic Kit is a simple, yet all-in-one I2C based RFID starting point for the ID-3LA, ID-12LA, and ID-20LA readers. Simply plug a reader into the headers and use a Qwiic cable to connect to any Qwiic enabled development board, then scan your 125kHz ID tag and the unique 32bit ID will be shown on the screen. This kit comes with everything you need to get started. The SparkFun RFID Qwiic Reader, an ID-12LA reader, a couple of RFID cards, and a cable to get you hooked up. Just plug this into any Qwiic enabled development board and you are good to go. Utilizing the onboard ATtiny84A, the Qwiic RFID takes the six byte ID tag of your 125kHz RFID card, attaches a time stamp to it, and puts it onto a stack that holds up to 20 unique RFID scans at a time. This information is easy to get at with some simple I2C commands. The unit comes with a read LED and buzzer, but don't worry, there is a jumper you can cut to disable the buzzer if you want. The SparkFun Qwiic Connect System is an ecosystem of I2C sensors, actuators, shields and cables that make prototyping faster and less prone to error. All Qwiic-enabled boards use a common 1mm pitch, 4-pin JST connector. This reduces the amount of required PCB space, and polarized connections mean you can’t hook it up wrong.   INCLUDES      1x SparkFun RFID Qwiic Reader 1x RFID Reader ID-12LA (125kHz) 2x RFID Tag (125kHz) 1x Qwiic Cable - 100mm FEATURES        Mates with three ID-XXLA RFID Modules o ID-3LA o ID-12LA o ID-20LA o 125kHz Read Frequency Scan range of 5-6 inches Buzzer and blue LED scan indicator Address Jumper Buzzer disconnect Jumper Interrupt disconnect Jumper        https://www.sparkfun.com/products/15209//3‐28‐19
KIT-15209 价格&库存
很抱歉,暂时无法提供与“KIT-15209”相匹配的价格&库存,您可以联系我们找货
