KIT-13844
KIT-13844
    SPARKFUNELECTRONICS
    INVENTOR KIT FOR ARDUINO 101
KIT-13844 数据手册
SparkFun Inventor's Kit for Arduino 101 KIT-13844 RoHS Open Source Hardware Description: The SparkFun Inventor’s Kit for the Arduino 101® board is a great way to get started with programming and hardware interaction with embedded electronics using the Intel® Curiebased Arduino 101 board. This 101 SIK includes everything you need to complete 21 circuits that will teach you how to control and read the on-board and external sensors, control the Arduino 101 through your phone, detect and analyze different sounds, and much more. Don’t worry; you won’t need any previous programming or electronics experience to use this kit. The philosophy behind this kit is that anyone can (and should) play around with cutting-edge electronics. After using this 101 SIK, you’ll have the know-how to start creating your own projects and experiments. From building robots and game controllers to IoT and data logging, the world will be your oyster. The online Experiment Guide for the Arduino 101 board contains step-by-step instructions on how to connect each circuit with the included parts. Full example code is provided and explained, and troubleshooting tips are included in case something goes wrong. The kit does not require any soldering and is recommended for anyone comfortable reading code libraries or anyone looking for an alternative to the original SparkFun Inventor’s Kit. Note: The Arduino 101 Inventor’s Kit is only available for customers in the USA. If you are located in Canada, the EU, or other locations, be sure to check out the Genuino 101 or its SIK instead. Additionally, this product may be delayed by two to three business days to verify shipping address. We will contact you after you place your order if we need anything. Note: The Real-Time Operating System (RTOS) and framework developed by Intel was scheduled to be open sourced in March 2016. It’s not possible to interface with it directly; only the Arduino core can do it via static mailboxes Circuit Experiments: Experiment 1: Blinking an LED Experiment 2: Reading a Potentiometer Experiment 3: Driving and RGB LED Experiment 4: Driving Multiple LEDs Experiment 5: Reading a Button Press Experiment 6: Reading an SPDT Switch Experiment 7: Reading a Photoresistor Experiment 8: Color Mixing with the RGB Experiment 9: Reading a Temperature Sensor Experiment 10: Driving a Servo Motor Experiment 11: Using a Transistor Experiment 12: Using the Motor Driver Experiment 13: Motor Driver with Inputs Experiment 14: Using a Piezo Buzzer Experiment 15: Using the Sound Detector Board Experiment 16: Using a Shift Register Experiment 17: Using an LCD Experiment 18: Reading the On-Board Accelerometer Experiment 19: Tap Detection Experiment 20: Using the On-Board Real Time Clock (RTC) Experiment 21: Using the On-Board Bluetooth Low Energy (BLC) Kit Includes: Arduino 101 Arduino and Breadboard Holder White Solderless Breadboard Carrying Case SparkFun Mini Screwdriver 16x2 White on Black LCD (with Headers) SparkFun Sound Detector (with Headers) SparkFun Motor Driver - Dual TB6612FNG (1A) (with Headers) Hobby Gearmotor - 200 RPM (Pair) Battery Holder - 4xAA to Barrel Jack Connector 74HC595 Shift Register Transistor - NPN (BC337) 1N4148 Diodes DC Motor with Gear Small Servo TMP36 Temp Sensor USB Cable A to B - 6 Foot Jumper Wires - Connected 6in. (M/M, 20 pack) Photocell Tri-color LED Red, Blue, Yellow, and Green LEDs Red, Blue, Yellow, and Green Tactile Buttons 10K Trimpot Piezo Speaker SPDT Mini Power Switch 100 Ohm and 10K Resistors 1500 mAh Alkaline Batteries - AA SparkFun Electronics ®
KIT-13844 价格&库存
很抱歉,暂时无法提供与“KIT-13844”相匹配的价格&库存,您可以联系我们找货
