KIT-13930
KIT-13930
    SPARKFUNELECTRONICS
    TINKER KIT W/ARDUINO
KIT-13930 数据手册
SparkFun Tinker Kit KIT-13930 RoHS Description: The SparkFun Tinker Kit (STK) is a great way to get started with programming and hardware interaction with the Arduino programming language. The STK is our newest version of the former SparkFun Mini Inventor’s Kit, blended with elements of our educator MESA kit. Each SparkFun Tinker Kit includes everything you need to complete 11 circuits that will teach you how to blink an LED, read sensors, drive servos, and more. You don’t need any previous programming or electronics experience to use this kit. The online STK Experiment Guide (in the Documents section below) contains step-by-step instructions of how to connect each circuit with the included parts. Full example code is provided and explained, and even includes troubleshooting tips in case something goes wrong. The kit does not require any soldering and is recommended for beginners ages 10 and up. This miniature version of the SIK will help prove that anyone can (and should) play around with cutting-edge electronics in a fun and playful way while not breaking the bank. Circuit Examples: Circuit 1: Blinking an LED Circuit 2: Reading a Potentiometer Circuit 3: Driving an RGB LED Circuit 4: Driving Multiple LEDs Circuit 5: Reading a Button Press Circuit 6: Reading a Photoresistor Circuit 7: Reading a Temperature Sensor Circuit 8: Using a Servo Motor Circuit 9: Driving a Motor with an H-Bridge Circuit 10: Controlling a Motor with Inputs Circuit 11: Reading Serial Data Kit includes: SparkFun RedBoard Breadboard - Self-Adhesive (White) Servo – Sub-Micro Size Hobby Gearmotor – 200 RPM (Pair) Temperature Sensor – TMP36 Mini Photocell SparkFun USB Mini-B Cable – 6 Foot Jumper Wires – 7" M/M 30 AWG (30 Pack) LED – RGB Clear Common Cathode Red, Blue, Yellow, and Green LEDs 10K Trimpot Momentary Pushbutton Switch – 12mm H-Bridge Motor Driver 1A Battery Holder - 4xAA to Barrel Jack Connector 330 and 10K Resistors SparkFun Electronics ®
KIT-13930 价格&库存
很抱歉,暂时无法提供与“KIT-13930”相匹配的价格&库存,您可以联系我们找货
