KIT-14526
KIT-14526
    SPARKFUNELECTRONICS
    Raspberry Pi Zero - 适配器
KIT-14526 数据手册
        Pi Zero USB Stem KIT-14526   The Pi Zero USB Stem is a PCB kit that turns a Raspberry Pi Zero into a USB dongle. Once the Stem is installed, your Raspberry Pi can be plugged directly into a computer or USB hub without any additional cables or power supplies. The Raspberry Pi then acts as a USB device using its own Linux kernel gadget drivers to get started. The Zero Stem is designed to be soldered directly to the USB SMD test pads on the bottom of the Raspberry Pi Zero, needing no wires or pogo pins at all, just solder and a soldering iron! Attaching the stem to your Pi also allows you to create a portable VNC server, or even cluster several Raspberry Pi Zeros with just a USB hub. The Zero Stem is compatible with the Raspberry Pi Zero v1.3 and the Raspberry Pi Zero W v1.1, but unfortunately it is not compatible with the Raspberry Pi Zero v1.2 or any full-size Raspberry Pi due to their shapes and sizes.   Includes      1x Pi Zero USB Stem 1x USB Connector 2x Nylon Bolt 2x Nylon Screw                                             https://www.sparkfun.com/products/14526 12‐28‐17
KIT-14526 价格&库存
很抱歉,暂时无法提供与“KIT-14526”相匹配的价格&库存,您可以联系我们找货
KIT-14526
  • 14+8.7115514+1.13248
库存:35
KIT-14526
    • 1+8.711551+1.13248
    库存:35
