KIT-15228
KIT-15228
    SPARKFUNELECTRONICS
    BBC micro:bit 发明人套件 micro:bit Microsoft MakeCode,Python 初级入门套件
KIT-15228 数据手册
        SparkFun Inventor's Kit for micro:bit KIT-15228 The SparkFun Inventor’s Kit (SIK) for micro:bit is a great way to get creative, connected and coding with the micro:bit. The SIK for micro:bit provides not only the micro:bit board but everything you need to hook up and experiment with multiple electronic circuits! With the SIK for micro:bit you will be able to complete circuits that will teach you how to read sensors, move motors, build Bluetooth®devices and more. The SparkFun Inventor’s Kit for micro:bit is the latest and greatest in single-board computer kits. Surrounding the micro:bit SIK is one core philosophy --- that anyone can (and should) experiment with cutting-edge electronics in a fun and playful way without breaking the bank. The kit does not require any soldering and is recommended for all users, from beginners to engineers. We have provided a complete Experiment Guide in the Documents tab for you to check out now! If you have ever been interested in learning about electronics, or if you have used the original SparkFun Inventor’s Kit and are looking for something new, the SIK for micro:bit is the perfect kit for you! The micro:bit is a pocket-sized computer that lets you get creative with digital technology. Between the micro:bit and our shield-like bit boards you can do almost anything while coding, customizing and controlling your micro:bit from almost anywhere! You can use your micro:bit for all sorts of unique creations, from robots to musical instruments and more. At half the size of a credit card, this versatile board has vast potential!   INCLUDES                      micro:bit Board SparkFun micro:bit Breakout (with Headers) Full-Size Breadboard micro:bit Battery Holder --- 2xAAA (JST-PH) Small Servo TMP36 Temperature Sensor Photocell USB Micro-B Cable --- 6 Foot Jumper Wires Alligator Clips with Pigtails RGB Diffused LED Red, Blue, Yellow and Green LEDs 10K Trimpot Multicolor Button --- 4-pack SPDT Mini Power Switch Mini Speaker 100 Ohm Resistors (Thick Leads) 10K Ohm Resistors (Thick Leads)   EXAMPLES                Circuit 0: Hello, micro:bit! Circuit 1: Blinking an LED Circuit 2: Reading a Potentiometer Circuit 3: Reading a Photoresistor Circuit 4: Driving an RGB LED Circuit 5: Reading an SPDT Switch Circuit 6: Reading a Button Press Circuit 7: Reading the Temperature Sensor Circuit 8: Using a Servo Motor Circuit 9: Using a Buzzer Circuit 10: Using the Accelerometer Circuit 11: Using the Compass                                                 https://www.sparkfun.com/products/15228/5‐14‐9
KIT-15228 价格&库存
很抱歉,暂时无法提供与“KIT-15228”相匹配的价格&库存,您可以联系我们找货
