KIT-15301
KIT-15301
    SPARKFUNELECTRONICS
    MICRO:CLIMATE KIT FOR MICRO:BIT
KIT-15301 数据手册
        SparkFun micro:climate kit for micro:bit KIT-15301 The SparkFun micro:climate kit is a full weather station kit that is built on top of the weather:bit carrier board. Unlike previous weather kits we've carried, the micro:climate kit includes our tried-andtrue Weather Meters and Soil Moisture Sensor, so whether you’re an agriculturalist, a professional meteorologist or a hobbyist, you will be able to build a high-grade weather station powered by the micro:bit. You can even talk via wireless communication between two micro:bits with this kit to be able to monitor the weather without being exposed to it! Inside each micro:climate kit you will find all the components required to build your micro:bit into a go-to weather sensor; the only parts not included are two AAA batteries and the micro:bit itself. Simply add your own micro:bit to the provided weather:bit, assemble the kit, and you will be ready to start sensing. The SparkFun micro:climate kit is a great way to get your feet wet in high-grade sensors --- just not literally; that's the weather:bit's job! The kit does not require any soldering and is recommended for anyone curious about weathersensing technology or the micro:bit platform. The micro:bit is a pocket-sized computer that lets you get creative with digital technology. Between the micro:bit and our shield-like bit boards you can do almost anything while coding, customizing and controlling your micro:bit from almost anywhere! You can use your micro:bit for all sorts of unique creations, from robots to musical instruments and more. At half the size of a credit card, this versatile board has vast potential! Note: The SparkFun micro:climate kit does NOT include a micro:bit board. The micro:bit board will need to be purchased separately. INDCLUDES          1x SparkFun weather:bit 1x Weather Meters 1x SparkFun Soil Moisture Sensor 1x SparkFun OpenLog 1x Waterproof Temperature Sensor 1x micro:bit Battery Holder --- 2xAAA (JST-PH) 1x Pocket Screwdriver Set 10x Jumper Wire (12in. M/M)                     https://www.sparkfun.com/products/15301/5‐14‐9
KIT-15301
物料型号包括: - SparkFun weather:bit - Weather Meters - SparkFun Soil Moisture Sensor - SparkFun OpenLog - Waterproof Temperature Sensor - micro:bit Battery Holder --- 2xAAA (JST-PH)
器件简介: - micro:bit是一个口袋大小的计算机,可以用于创意数字技术。
引脚分配参数特性没有在文档中明确说明。
功能详解: - 该套件可以构建一个基于micro:bit的气象传感器。 - 可以通过两个micro:bit之间的无线通信来监测天气。
应用信息: - 适合用于构建高级气象站。
封装信息: - 套件包括所有构建所需组件,除了两个AAA电池和micro:bit本身。
KIT-15301 价格&库存
很抱歉,暂时无法提供与“KIT-15301”相匹配的价格&库存,您可以联系我们找货
