KIT-16274
KIT-16274
    SPARKFUNELECTRONICS
    气象站 micro:bit,SparkFun’s Qwiic 物理科学
KIT-16274 数据手册
        SparkFun micro:climate kit for micro:bit - v3.0 KIT-16274 The SparkFun micro:climate kit is a full weather station kit that is built on top of the weather:bit carrier board. Unlike previous weather kits we've carried, this micro:climate kit is Qwiic enabled and includes our tried-and-true Weather Meters and Soil Moisture Sensor, so whether you’re an agriculturalist, a professional meteorologist or a hobbyist, you will be able to build a high-grade weather station powered by the micro:bit. You can even talk via wireless communication between two micro:bits with this kit to be able to monitor the weather without being exposed to it! Inside each micro:climate kit you will find all the components required to build your micro:bit into a go-to weather sensor; the only parts not included are two AAA batteries, microSD card, and the micro:bit itself. Simply add your own micro:bit to the provided weather:bit, assemble the kit, and you will be ready to start sensing. The SparkFun micro:climate kit is a great way to get your feet wet in high-grade sensors --- just not literally; that's the weather:bit's job! The kit does not require any soldering and is recommended for anyone curious about weathersensing technology or the micro:bit platform. The micro:bit is a pocket-sized computer that lets you get creative with digital technology. Between the micro:bit and our shield-like bit boards you can do almost anything while coding, customizing and controlling your micro:bit from almost anywhere! You can use your micro:bit for all sorts of unique creations, from robots to musical instruments and more. At half the size of a credit card, this versatile board has vast potential! Note: The SparkFun micro:climate kit does NOT include a micro:bit board. The micro:bit board will need to be purchased separately. You will also need a microSD card when logging data and AAA batteries to power remotely. INCLUDES         1x SparkFun weather:bit (Qwiic) 1x Weather Meter Kit 1x SparkFun Soil Moisture Sensor 1x SparkFun OpenLog 1x Waterproof Temperature Sensor 1x micro:bit Battery Holder --- 2xAAA (JST-PH) 1x Pocket Screwdriver Set 10x Jumper Wire (12in. M/M)             https://www.sparkfun.com/products/16274/2‐10‐20
KIT-16274 价格&库存
很抱歉,暂时无法提供与“KIT-16274”相匹配的价格&库存,您可以联系我们找货
KIT-16274
    库存:5
