KIT-16327
KIT-16327
    SPARKFUNELECTRONICS
    Raspberry Pi 项目套件
KIT-16327 数据手册
    SparkFun Raspberry Pi Zero W Camera Kit KIT-16327 ROHS The SparkFun Raspberry Pi Zero W Camera Kit provides you with a pan/tilt camera controlled via a Raspberry Pi Zero W. This kit consists of parts that are easy to assemble and program, expanding the Raspberry Pi Zero W's IoT capabilities and highly tailored accessibility to the Pi Camera Module. With the Zero W camera kit, you will be able to create homemade motionactivated security systems, webcam interfaces for streaming, or monitoring stations for any number of projects and adventures. After just a few steps you'll be set up in no time with your very own remote camera system! Inside this kit is everything you need to assemble your pan/tilt camera, including a Raspberry Pi Zero W, our own Pi Servo pHAT, a Raspberry Pi Camera Module V2, a pan/tilt bracket with servos, and all the cables and headers you need to hook them all up. Note: The Pan/Tilt Bracket in this kit does not come pre-built, so some assembly is required. Check our Documents for a complete Assembly Guide. INCLUDES          1x Raspberry Pi Zero W w/ Headers 1x SparkFun Pi Servo pHAT 1x Raspberry Pi Camera Module V2 1x Raspberry Pi Zero Case w/ Short Camera Cable 1x Pan/Tilt Bracket Kit 1x Raspberry Pi Zero Camera Cable 1x Raspberry Pi GPIO Male Header - 2x20 1x Raspberry Pi GPIO Tall Header - 2x20 1x Double-Sided Foam Tape Square - 1in. FEATURES Revision Changes: With this revision of the SparkFun Raspberry Pi Zero W Camera Kit, we have swapped out two individual boards inside the kit, listed below. If users are unsure about which version they purchased, please refer to the product pictures.   The SparkFun Pi Servo HAT has been replaced with the SparkFun Pi Servo pHAT. The Raspberry Pi Zero W has been replaced with the Raspberry Pi Zero W w/ Headers.                             https://www.sparkfun.com/products/16327/7‐22‐20
KIT-16327 价格&库存
很抱歉,暂时无法提供与“KIT-16327”相匹配的价格&库存,您可以联系我们找货
KIT-16327
    库存:500
