LCD-15079
LCD-15079
    SPARKFUNELECTRONICS
    QWIIC TRANSPARENT OLED HUD BOARD
LCD-15079 数据手册
  SparkFun Transparent OLED HUD Breakout (Qwiic) LCD-15079   Clear screens are no longer a thing of the Sci-Fi world! The Qwiic Transparent OLED HUD is SparkFun's answer to all of your futuristic transparent HUD needs. Designed for use in vehicle heads-up displays, this OLED panel is brilliant in the dark but easily visible in daylight. The display is "area colored" meaning that while no one segment can change colors, there are different colored segments on the display. The SparkFun Transparent OLED Breakout allows you to easily control the display using the I2C protocol and includes a voltage step-up to generate the panel's 12V driving voltage from Qwiic's 3.3V bus. To make things even easier, we've thrown together an Arduino library so that doing things like changing the speedometer read out is as easy as calling setSpeedometer() in your sketch. Utilizing our handy Qwiic system, no soldering is required to connect it to the rest of your system. However, we still have broken out 0.1"-spaced pins in case you prefer to use a breadboard. The Arduino sketch required to drive this display requires quite a bit of dynamic memory, meaning that it is not going to fit on a smaller controller like an ATmega328. Any controller with larger RAM should have no problem. It has been tested to run very well on an Arduino Mega 2560. In addition, your 3.3v source should be robust enough to supply around 400mA to the display. The SparkFun Qwiic Connect System is an ecosystem of I2C sensors, actuators, shields and cables that make prototyping faster and less prone to error. All Qwiic-enabled boards use a common 1mm pitch, 4-pin JST connector. This reduces the amount of required PCB space, and polarized connections mean you can’t hook it up wrong. INCLUDES   1 x Transparent OLED Display 1 x Qwiic HUD Breakout Board FEATURES       106.00mm x 37.90mm Panel Size Totally Transparent Segmented Display with 230 separate segments Requires 3.3V at ~500mA I2C Addresses: 0x30, 0x31 2x Qwiic Connectors        https://www.sparkfun.com/products/15079/3‐7‐19
LCD-15079 价格&库存
很抱歉,暂时无法提供与“LCD-15079”相匹配的价格&库存,您可以联系我们找货
