LCD-15173
LCD-15173
    SPARKFUNELECTRONICS
    TRANSPARENT GRAPHICAL OLED BREAK
LCD-15173 数据手册
  SparkFun Transparent Graphical OLED Breakout (Qwiic) LCD-15173 Open Source Hardware The future is here! The SparkFun Qwiic Transparent Graphical OLED Breakout allows you to display custom images on a transparent screen using either SPI or I2C connections. Brilliantly lit in the dark and still visible by daylight, this OLED sports a display area of 128x64 pixels, 128x56 of which are completely transparent. Utilizing our handy Qwiic system, no soldering is required to connect it to the rest of your system making it easy to get started with your own images. However, we still have broken out 0.1"-spaced pins in case you prefer to use a breadboard. The Arduino sketch required to drive this display requires quite a bit of dynamic memory, meaning that it is not going to fit on a smaller controller like an ATmega328. Control of the OLED is based on our new HyperDisplay library and any controller with larger RAM should have no problem. In addition, your 3.3V source should be robust enough to supply around 400mA to the display. The SparkFun Qwiic Connect System is an ecosystem of I2C sensors, actuators, shields and cables that make prototyping faster and less prone to error. All Qwiic-enabled boards use a common 1mm pitch, 4-pin JST connector. This reduces the amount of required PCB space, and polarized connections mean you can’t hook it up wrong. FEATURES           128x56 transparent pixels (128x64 total pixels) Display area 35.5 x 18mm Glass area 42mm x 27.16mm 1-bit color depth I2C or SPI operation 400 kHz I2C, 10 MHz SPI I2C Addresses: 0x30 (Default), 0x31 Qwiic compatible and standard PCB footprint Operates and communicates at 3.3V Less than 200 mA current draw pixels all-on        https://www.sparkfun.com/products/15173/3‐15‐19
LCD-15173 价格&库存
很抱歉,暂时无法提供与“LCD-15173”相匹配的价格&库存,您可以联系我们找货
