PRT-11855
PRT-11855
    SPARKFUNELECTRONICS
    LI-ION BATTERY 1AH
PRT-11855 数据手册
      Lithium Ion Battery - 1000mAh 7.4v PRT-11855 ROHS   This high discharge LiPo is a great way to power any R/C, robotic, or portable project. This is an excellent choice for anything that requires a small battery with a lot of punch. The voltage is low enough not to tax your regulating circuits, and the discharge rate is high enough to accommodate a lot of electronics and a few small motors. The battery has two cells and outputs 7.4V storing 1000mAh of charge. Because this is a dual cell battery pack, a special charger is needed. This battery is not compatible with single cell chargers. A compatible charger is listed below. Note: This battery is not available to ship to Alaska or Hawaii, or through any express services (2day, overnight), or internationally. This is temporary! Check out our blog post for more information. Additionally orders may take longer to process and therefore do not qualify for same-day shipping. Sorry for any inconvenience this may cause! Note: Care should be taken not to short circuit or overtax these batteries because they don’t have any built-in protection circuit. Note: This item is non-returnable. If this item arrives damaged or is not functioning properly, please do not hesitate to contact us to see if further actions may be taken. Weight: 85g (2.99oz) Replaces:PRT-10472   FEATURES        7.4V 2-cell pack 1000mAh of charge 25C continuous discharge rate JST-XH charge plug Dean’s Connector discharge plug 70mm x 35mm x 18mm                                                      https://www.sparkfun.com/products/11855 6‐19‐18
PRT-11855 价格&库存
很抱歉,暂时无法提供与“PRT-11855”相匹配的价格&库存,您可以联系我们找货
