PRT-11856
PRT-11856
    SPARKFUNELECTRONICS
    LI-ION BATTERY 2.2AH
PRT-11856 数据手册
      Lithium Ion Battery - 2200mAh 7.4v PRT-11856 ROHS   This high discharge LiPo is a great way to power any R/C, robotic, or portable project. This is an excellent choice for anything that requires a small battery with a lot of punch. The voltage is low enough not to tax your regulating circuits, and the discharge rate is high enough to accommodate a lot of electronics and a few small motors. The battery has two cells and outputs 7.4V storing 2200mAh of charge. Because this is a dual cell battery pack, a special charger is needed. This battery is not compatible with single cell chargers. A compatible charger is listed below. Note: This battery is not available to ship to Alaska or Hawaii, or through any express services (2day, overnight), or internationally. This is temporary! Check out our blog post for more information. Additionally orders may take longer to process and therefore do not qualify for same-day shipping. Sorry for any inconvenience this may cause! Note: Care should be taken not to short circuit or overtax these batteries because they don’t have any built-in protection circuit. Note: This item is non-returnable. If this item arrives damaged or is not functioning properly, please do not hesitate to contact us to see if further actions may be taken. Weight: 206g (7.26oz) Replaces:PRT‐10471  FEATURES        7.4V 2-cell pack 2200mAh of charge 30C continuous discharge rate JST-XH charge plug Dean’s Connector discharge leads 138.5mm x 47.5mm x 24.5mm                                                          https://www.sparkfun.com/products/11856‐19‐18
PRT-11856 价格&库存
很抱歉,暂时无法提供与“PRT-11856”相匹配的价格&库存,您可以联系我们找货
