PRT-12043
PRT-12043
    SPARKFUNELECTRONICS
    无焊剂试验电路板 端子条(无框架) 1.85" x 1.38"(47.0mm x 35.0mm)
PRT-12043 数据手册
    Breadboard ‐ Mini Modular (White) PRT-12043 RoHS Description: This white Mini Breadboard is a great way to prototype your small projects! With 170 tie points there’s just enough room to build and test simple circuits; They’re also great for breaking out DIP package ICs to jumper wires! If you run out of room, no worries, these mini breadboards can be snapped together to form larger stretches of board. It has a peel and stick adhesive backing as well as two mounting holes for M2 screws so you can anchor it down. Note: These will not connect securely with our older model and are not numbered or lettered. Dimensions: 47 x 35 x 10mm Replaces:PRT-11658        https://www.sparkfun.com/products/12043 5‐16‐17
PRT-12043 价格&库存
很抱歉,暂时无法提供与“PRT-12043”相匹配的价格&库存,您可以联系我们找货
