PRT-12045
PRT-12045
    SPARKFUNELECTRONICS
    BREADBOARD TERM STRIP 1.85X1.38"
PRT-12045 数据手册
      Breadboard ‐ Mini Modular (Blue) PRT-12045 RoHS    Description: This blue Mini Breadboard is a great way to prototype your small projects! With 170 tie points there’s just enough room to build and test simple circuits; They’re also great for breaking out DIP package ICs to jumper wires! If you run out of room, no worries, these mini breadboards can be snapped together to form larger stretches of board. It has a peel and stick adhesive backing as well as two mounting holes for M2 screws so you can anchor it down. Note: These will not connect securely with our older model and are not numbered or lettered. Dimensions: 47 x 35 x 10mm        https://www.sparkfun.com/products/12045 5‐16‐17
PRT-12045 价格&库存
很抱歉,暂时无法提供与“PRT-12045”相匹配的价格&库存,您可以联系我们找货
