Breadboard ‐ Mini Modular (Green)
PRT-12046 RoHS
Description: This green Mini Breadboard is a great way to prototype your small projects! With 170
tie points there’s just enough room to build and test simple circuits; They’re also great for breaking
out DIP package ICs to jumper wires! If you run out of room, no worries, these mini breadboards can
be snapped together to form larger stretches of board. It has a peel and stick adhesive backing as
well as two mounting holes for M2 screws so you can anchor it down.
Note: These will not connect securely with our older model and are not numbered or lettered.
Dimensions: 47 x 35 x 10mm
https://www.sparkfun.com/products/12046 5‐16‐17
很抱歉,暂时无法提供与“PRT-12046”相匹配的价格&库存,您可以联系我们找货
